Re: Clutch alignment tool
Posted by old on September 05, 2012 at 14:58:23 from (209.86.226.40):
In Reply to: Clutch alignment tool posted by BigTone on September 05, 2012 at 14:33:29:
Just as Rusty says to do it. All it does is hold the clutch disk in place so when you go to put the input shaft in it will fit. If the clutch disk is not lined up as it should be you can not put the 2 halve back together and many a clutch disk has been destroyed because of not have the disk lined up
