Re: Farmall 300 Part name with Pic.
Posted by D Slater on September 05, 2012 at 17:24:55 from (184.15.8.74):
In Reply to: Farmall 300 Part name with Pic. posted by Nate V. IA on September 05, 2012 at 15:17:08:
Looks like the throttle rod from the shaft and levers in the center support frame work behind the engine to the governor operating lever. Probably bent to make it shorter. Should be straight, probably a problem with the linkage up to that rod. Plenty of pins and linkage parts from the throttle lever to there that can give a problem on a well used 100 series tractor.
