Re: C Hydraulic tank and lift on BN
Posted by gene bender on September 06, 2012 at 04:50:48 from (207.177.56.236):
In Reply to: C Hydraulic tank and lift on BN posted by Brad Motheral on September 05, 2012 at 14:34:21:
I have one someone built you also need to use the C gas tank for mounting and the sediment bowl placement. They built a batt box and welded the steering post to the lid so they could use the hy controls from the C. They did a fine job and had a disc plow from a SA mounted. I use it with a blade on the back and made brackets for Allis Chalmers planting units for sweetcorn using the rockshaft for lifting the planters. They kept the Bs lite sw assy.
