Re: C Hydraulic tank and lift on BN
Posted by mkirsch on September 06, 2012 at 05:17:36 from (64.80.110.74):
In Reply to: C Hydraulic tank and lift on BN posted by Brad Motheral on September 05, 2012 at 14:34:21:
You need to change so many parts, that you may as well get a whole other tractor.
You need a different engine block with the hydraulic pump.
You need a different torque tube with the flat mounting surface.
You need a different gas tank with the sediment bowl in the right place.
