Re: H belly pump
Posted by mkirsch on September 06, 2012 at 05:31:40 from (64.80.110.74):
In Reply to: H belly pump posted by alderman on September 06, 2012 at 05:05:33:
The belly pump is in the belly of the tractor. Hence, belly pump.
None of the pictures you posted, that I've seen, show that portion of the tractor.
Look under the belly of the tractor, below the gas tank. You should see a cast steel unit protruding down below the belly of the tractor. It is kind of rounded, has a removable plug to drain, and there is a key-shaped hole on either side.
