Re: H belly pump
Posted by Zachary Hoyt on September 06, 2012 at 05:34:44 from (184.12.64.194):
In Reply to: Re: H belly pump posted by alderman on September 06, 2012 at 05:17:01:
If you look at the tractor just behind where the clutch is you will see three pipes coming out through the casting and an arm with a rod attached to it that runs up toward the seat area. On the bottom if you look up inside the torque tube you will see a big cast boxy shape with a short thick drive shaft running from it to the front of the transmission. If you need a belly pump or any parts I have everything here and can ship.
Zach
