Re: H belly pump
Posted by jt on September 06, 2012 at 07:51:31 from (66.87.75.89):
In Reply to: Re: H belly pump posted by alderman on September 06, 2012 at 05:17:01:
If the H has a three point, as you.stated, it is more than likely hydraulically operated. If it is, followthe hydraulic hose to where it hooks to tractor. That should be one of the ports of the belly pump, unless someone has put a live pump behind the mag to run three point hydraulics.
