Re: farmall h oil pressure
Posted by rustyfarmall on September 07, 2012 at 04:51:48 from (67.55.162.174):
In Reply to: farmall h oil pressure posted by randy hall on September 06, 2012 at 20:33:19:
Yes, the bottom cover on an H oil pump is heavy enough that it does not warp easily, but that thin little gasket can still blow out, and the gears inside the pump WILL wear some serious depressions into the cover, and when that happens, there will be a serious loss of oil pressure.
