Re: 200 only sparking on one cylinder
Posted by Jon Hagen on September 07, 2012 at 11:15:47 from (69.26.17.61):
In Reply to: 200 only sparking on one cylinder posted by Dodge2500 on September 05, 2012 at 13:28:02:
Connect a dwell meter to the tractor and crank it over with the ignition on, coil tower wire grounded. Watch if the dwell reading remains fairly constant or changes a lot.
If it indicates more than 2-3 degrees change from cylinder to cylinder, you have a worn distributor shaft point cam, worn shaft and bushings, or a bent distributor shaft.
