Re: IH 100 Spreader
Posted by jimb2 on September 07, 2012 at 17:42:40 from (99.241.38.122):
In Reply to: Re: IH 100 Spreader posted by countrygal on September 07, 2012 at 15:48:14:
Hi Countrygal, my brother had an IH forage box
with same chain and idler. Idler broke and part
was no longer available from CNH. He found one at
TSC that was the same size but sprocket tooth
spacing was twice the original. So sprocket tooth
only went into every second link in the chain
which was OK for an idler as its only purpose was
to keep the chain tension. When another idler
broke, we ended up replacing with a semi-circle
piece of maple. We soaked the maple in oil for a
day and put some grease on it from time to time.
Hope this helps
JimB
