Re: 4 bottom plow change over to 3 bottom??
Posted by mkirsch on September 08, 2012 at 11:49:09 from (67.253.161.186):
In Reply to: 4 bottom plow change over to 3 bottom?? posted by Matt (NEIA) on September 08, 2012 at 07:40:41:
Only problem with dropping the 4th bottom on a 3pt plow is side draft.
The plow is set up to pull straight with 4 bottoms. The 3pt hookup is centered between the 2nd and 3rd bottoms.
When you remove the 4th bottom will pull uneven to the right, unless the 3pt can be slid sideways on the plow frame to re-center it on 3 bottoms.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
