Re: 4 bottom plow change over to 3 bottom??
Posted by The tractor vet on September 08, 2012 at 15:34:55 from (76.212.230.88):
In Reply to: Re: 4 bottom plow change over to 3 bottom?? posted by DeltaRed on September 08, 2012 at 11:47:18:
Lot of difference between a rollover then a mounted or semi mounted Most and again i say most I H plows were based on a three bottom BUT there were a couple that were made as a four bottom and that is what your stuck with as if you try and drop a bottom they will Draft sideways . Just about like a five bottom onland plum sucks but the same plow in a 6-8 bottom is better and pulls easier . If you can handle five in the furrow then you can handle 6 onland just as easy if not easier at the same gear with better ground speed. Like when i first started farming on my own i had a Farmall 450 D and bought a set of 311 's in 3x14 while my buddy had a set of 540in 4x14's semi mounts with a harrow mounted on the plow . Both of us in the same field and me pulling one less bottom i should have walked all over him , not so we were both in third gear and i could not gain on him . One day i hooked to his plow just to see if my 450 had what his had the 540's pulled that much easier that i could pull the 4 bottoms in the same gear at the same depth as i was pulling the three bottom mounted . The 311's took a ride and i found a set of 540's with super chef bottoms where his plow had the Plow Chef bottoms adde a harrow and we cut our disking down to dead furrows and head lands for corn ground. Never went back to a mounted plow after that.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
