Re: Super A blowing oil
Posted by Janicholson on September 08, 2012 at 18:30:36 from (96.24.99.126):
In Reply to: Super A blowing oil posted by Joe in CA on September 07, 2012 at 22:44:43:
Have you looked at the oil level in the crank case. If your Hydraulic pump is leaking into the engine, it will literally fill the crank case. If that is not it, a holed piston or trashed rings would be my guess. Jim
