Re: Super M 3pt
Posted by Old Iron on September 08, 2012 at 19:12:58 from (24.225.2.121):
In Reply to: Super M 3pt posted by jeffalex2 on September 07, 2012 at 14:48:37:
I've bought 2 new Saginaw 3-pts. over the years, and bought an M with one already on it.
I put one of the new ones on a Super M, and the other on a Farmall 400.
They're a bit expensive, but worth every penny and designed very well.
I especially like the option of "power-down" when using a post-hole auger in hard ground or when putting on tire chains.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
