Re: No wonder my starter was dragging!
Posted by Owen Aaland on September 08, 2012 at 21:56:05 from (216.47.35.212):
In Reply to: No wonder my starter was dragging! posted by Brendon-KS on September 06, 2012 at 14:29:09:
The magnetic force IS determined by the current (and the number of turns in the coil). When you put 12 volts to a starter that is designed for six volts you are not only doubling the voltage but since you are not changing the resistance the current also doubles.
