Posted by caterpillar guy on September 09, 2012 at 06:40:08 from (68.188.235.228):
In Reply to: H Lift-All Pressure posted by FBH44 on September 09, 2012 at 05:38:53:
The early ones were about 5-600PSI then later they went up to about 850 PSI. Why would you doubt water pipe fittings I have used them on pressure in the 2000PSI like 806 and 1466 tractors. There is a difference in hyd fittings with pipe threads and water pipe fittings. The water pipe fittings are bushings or couplings. Unless you deadhead the pressure the pressure is only as great as it takes to lift the item you are using.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
