Re: Plenty of spark F-14
Posted by Bill in NJ on September 10, 2012 at 05:57:20 from (4.248.65.48):
In Reply to: Re: Plenty of spark F-14 posted by John M on September 10, 2012 at 03:24:47:
First off, your spark jumping and red glow problems have nothing to do with fuel mixture or for that mattter your fuel delivery system. Sounds like the #2 plug wire is either cracked or too close to the manifold. Could be both. If posible, reposition it so the terminal is as far away from ANY metal as possible. The red glow problem is more than likely dirt and/or rust at the terminal causing resistance which will create heat. Old rule of thumb = clean, bright and tight.
