Re: M question
Posted by The tractor vet on September 10, 2012 at 10:15:45 from (75.24.7.240):
In Reply to: Re: M question posted by oldtanker on September 10, 2012 at 09:01:06:
I have played this game before . Yea ya can do a lot with a M , BUT the money involved is gotten out of hand . It can be done on the cheap side BUT not with a Farmall The best yo can do on the cheaper side is by going with a S/M block and put a set of High alt. pistons and a 450 head not the LP head Put bigger valves have the cam reground a 450 manifold a little carb work and gov. work a little dist recurve and ya might make 100 Hp. after that your talking a deeper check book. The cheapest pulling tractor that we built was a MM U and for two years dominated the 4500 -7500 div three in my area. It was built with almost all junk parts Two junk broken blocks 4 used cummings 855 sleeves four used farmall M rods two junk 4210 MM heads used John deere valves four used Allison pistons A junk crank welded up and offset ground crank a reground cam a new Bendix huge up draft carb one of my recurved dist. a set of half wore out 16.9x38 Firestone deep treads . We had a monster . it did not matter who was setting in the drivers seat it was a out the gate everytime but on that that happened on her first pull on the third run with me in the seat . The holley fuel pump locked up at about the 285 foot mark with a full head of steam and got hit in the donkey by the sled and shoved to the 290 foot marker and still won the class.
