Posted by Teakettle on September 10, 2012 at 10:58:24 from (18.85.36.2):
In Reply to: IH 784 Hydraulics posted by gac on September 09, 2012 at 18:17:50:
Put a bucket or oil change pan under it when you take it off. There will probably be a pint or two of oil coming out.
The screen that sits above the filter will likely have a thick layer of crud on it (possibly including the lining from your parking brake band if anyone ever tried to drive with the brake engaged). A can of spray brake cleaner works well to clean it.
The gasket is a bit floppy and you need to be careful that it stays under the lip of the cover when you tighten things down.
Overall only a 15 minute job if things aren't too gunky in there.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
