Re: Dangit! what did I screw up
Posted by CNKS on September 10, 2012 at 18:30:34 from (216.144.104.128):
In Reply to: Dangit! what did I screw up posted by Paul Shuler on September 10, 2012 at 18:18:07:
As to the battery the only way you could have hurt anything is if you have an alternator. Voltage regulator, maybe after a long period of time, not just a few minutes. In your haste you probably flooded it. Will probably start immediately tomorrow.
