Re: H points and condenser
Posted by gene bender on September 11, 2012 at 02:04:22 from (67.55.226.59):
In Reply to: H points and condenser posted by j hakenwerth on September 10, 2012 at 16:41:19:
Take your timing lite when the engine is running at lower rpms and hook the pickup for the lite from one wire to the next and watch the fire pattern and you will probably see bad firing meaning a worn shaft in the dist.
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
