Re: Hydraulic system flush
Posted by IH fan on September 11, 2012 at 02:09:30 from (108.238.224.66):
In Reply to: Hydraulic system flush posted by John G. Hasler on September 10, 2012 at 22:49:18:
NO they will not. It takes a special filter to remove water and I doubt you will find one that fits. We had a special portable "kidney loop" setup with the water absorbing elements in it in our test lab. Your best bet is to drain the system, open and drain all the lines you can get to and fill it with new fluid. You won't get 100%, but you also need to find where the water got in and seal it.
