Posted by Owen Aaland on September 11, 2012 at 11:52:22 from (216.47.35.208):
In Reply to: H popping out of gear posted by 1950 MFD on September 10, 2012 at 21:47:45:
About nine out of ten times for the ones I have worked on replacing the main shaft front bearing cured the problem of jumping out of fifth. As long as the bearings do not have excessive play the gears can be quite worn before they cause problems.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
