Re: 1566 air conditioning
Posted by Owen Aaland on September 11, 2012 at 14:43:57 from (216.47.35.45):
In Reply to: 1566 air conditioning posted by jdetig1 on September 11, 2012 at 11:30:40:
On the 66 series tractors the condenser is located on the back of the cab. The evaporator is inside the cab. If you still have the original York compressor there should S and a D cast into the compressor head. The larger hose hose will be the low side and the smaller hose the high side. You will also need to replace the oil with the correct oil for R134A. Charge the system to about 80% of the total capacity for R12 refrigerant.
R12 charge 71 to 80 ounces
Oil 6 to 12 ounces
Oil level 7/8 to 1-7/16
This post was edited by Owen Aaland at 15:37:55 09/11/12.
