Re: Update to dang it! Battery backwards
Posted by ken house on September 11, 2012 at 17:28:24 from (173.242.240.50):
In Reply to: Update to dang it! Battery backwards posted by Paul Shuler on September 11, 2012 at 16:44:50:
hey, don't fret over a little mistake, it doesn't get any better. i am 69 years old.
proper electric hook up on 6 v, + always faces ground. so coming from battery, + goes to - side of coil and coming from coil + faces distributor or ground.
Have you fire coming to coil? if so remove lead wire from coil to distributor at the distributor, replace distributor high voltage wire with spark plug wire and connect to an extra spark plug and ground the plug. ignition switch on and strike loose end of lead wire to ground, if plug fires, coil is good.
