Re: Update to dang it! Battery backwards
Posted by old on September 11, 2012 at 17:48:24 from (209.86.226.40):
In Reply to: Update to dang it! Battery backwards posted by Paul Shuler on September 11, 2012 at 16:44:50:
Unless it has electronic ignition you did not hurt the ignition system any. But what could be wrong is very simple like the points needing to be cleaned or replaced. Pull the cap/rotor/dust cover and turn the ignition on and open and close the points by hand. You should both hear and see a spark. No spark points need to be cleaned and or replaced.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
