Re: Gas line replacement on 450
Posted by rustyfarmall on September 12, 2012 at 07:05:22 from (67.55.162.174):
In Reply to: Gas line replacement on 450 posted by earl in pa on September 12, 2012 at 06:35:22:
Unless you are into pulling, and have a highly modified engine, there is no need for it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
