Well first off make sure you have a good blue/white spark that will jump a 1/4 inch gap or more. Then check your oil bath air cleaner and make sure it is not all full of water or dirt and also make sure the up pipe is not full of dirt dobber nests. Next pull the tube from the air clean to the carb and make sure the air area of the carb is not sitting full of gas. If you find the air intake full of gas you may have a bad float of sticking float and that would cause it to run rich. I do not know if that carb has a main jet adjustment screw but if it does and you have checked every thing else you might adjust that screw in a turn or 2. The problem you have sounds like it is running way to rich but any of the things I said can cause that to happen
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
