Re: ih 674 power steering/hydraulic issues
Posted by mbnok on September 12, 2012 at 14:02:45 from (76.225.40.252):
In Reply to: ih 674 power steering/hydraulic issues posted by PAlogging on September 12, 2012 at 10:31:15:
When you change the filter look carefully at the stuff that is on it. If it is mostly soft and brown then it is probably brake material. Use a magnet on it
You may even find some metal grindings. You block it up good and work your way from the back wheel and axel housing into the brakes and replace them. takes time and the removal of lots of parts. Not that hard to do. Just be careful.
