Re: Starter
Posted by gene bender on September 12, 2012 at 16:40:36 from (67.55.227.236):
In Reply to: Starter posted by edw on September 12, 2012 at 15:30:02:
So what else have you goofed up as they used a saddle sw you pulled with battery positive cable fastened there. You say a push button sw so something is also messed up or it would start. You must have the wrong starter or you couldnt have a push button to start as original had a button for the sw to make contac and you pulled a rod.
