Re: Tractor Ride push pole or chain
Posted by sflem849 on September 13, 2012 at 06:40:16 from (64.134.173.207):
In Reply to: Tractor Ride push pole or chain posted by Va Gasman on September 13, 2012 at 05:14:09:
A push/pull pole is better, but it would only work if the tractors are hooked drawbar to drawbar. (one guy would be backwards) OR if you put a front hitch on your tractor it would work with both going forward. Problem with that is you don't want to pull a tractor too far like that because the trans will not get sufficient.
So IMO bring your chain and it will get your off the road. I wouldn't pull my tractor to finish the ride, but that is my opinion.
That push/pull pole works GREAT for loading a dead tractor onto the trailer. We use a pickup rather than a tractor for a little more control.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
