Re: Cams
Posted by Andrew Z on September 14, 2012 at 06:41:10 from (72.10.122.33):
In Reply to: Cams posted by bassndeere on September 13, 2012 at 17:17:33:
Just as Jim says they are different the Super H and 300 are a good jump up from the H cam. Yet the 350 cam is slightly better yet. Lift is longer, duration is near or is the same. If you put a 350 cam in the H with nothing else done to it, it will gain a few hp and a few ft lbs. Also the fuel economy will slope off some. Depends what you want to do with it. You can have a cam ground to obtain custom specs be it better low end or higher end. But again in a stock engine its not going to go too too far.
Andrew
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
