Re: M Bolster Shaft Size Measurements
Posted by Bob M on September 14, 2012 at 08:16:39 from (74.67.190.208):
In Reply to: M Bolster Shaft Size Measurements posted by big a on September 13, 2012 at 20:13:50:
You might first install new bushings in the fixed bolster. Then measure the ID of each bushing and subtract .005 -.007" from each. This should give you an accurate OD to machine the pivot shaft bearing surfaces to give a good fit to YOUR tractor.
