Re: Who has a Farmall 560
Posted by John A. on September 14, 2012 at 09:24:36 from (64.128.16.238):
In Reply to: Who has a Farmall 560 posted by IHFORDFARMER on September 14, 2012 at 09:03:22:
IHFORDFARMER, Check the Tag, See if there is a small triangle,,a Delta sign,, after the Serial #. If it has, them it probably had an up date on the rearend. Just after those tractors came out they had a bunch of rearend bearing problems and the tractor that got the update were stamped with the Delta sign after the Serial # Hope this helps.
Later,
John A.
