Re: How do you time a M?
Posted by glennster on September 14, 2012 at 14:37:59 from (75.57.143.173):
In Reply to: How do you time a M? posted by BigTone on September 14, 2012 at 09:00:08:
like janicholson said, static time the engine, unless your timing light has an advance function, you wont time it correctly with a light. look for two marks close together on the crankshaft pulley. the first mark in the direction of rotation is tdc. that is where you want to be for a distributor ignition. there should be a single mark a ways around the pulley. if you happen to line that up with the timing pointer, then crawl under the tractor and look up in the hole at the bottom of the bell housing, you will see the grease zerk in the fly wheel to lube the pilot bearing. pretty tricky eh?
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
