Re: Removing coupling on H belly pump
Posted by charlie M on September 14, 2012 at 17:13:36 from (74.34.216.81):
In Reply to: Re: Removing coupling on H belly pump posted by BruceS. on September 14, 2012 at 17:03:18:
You have to insert rod into the pump to prevent the gears from turning and then unscrew the coupling. I believe it has reverse threads.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
