Re: Starter for a Farmall A
Posted by gene bender on September 15, 2012 at 02:56:11 from (67.55.227.72):
In Reply to: Starter for a Farmall A posted by charlie M on September 14, 2012 at 17:17:43:
You can change the nose to make the holes line up as your starter should have a button and a saddle sw that you push to start the engine. Correct Delco# at the end of the tag should be 021. Too many of the starters on the A and B series have been changed with incorrect starters some like yours with a stud then needing a solenoid or heavy sw like Hand M used. You can get the correct rebuilts just get the correct one for an A OR a B the SA AND c,sc have the button on the other end and their sw are pull type.
