Re: Adjusting pto shaft length on #5 JD sickle bar
Posted by MN Scott on September 15, 2012 at 07:09:53 from (184.158.69.94):
In Reply to: Adjusting pto shaft length on #5 JD sickle bar posted by Pat B im Mich on September 14, 2012 at 17:36:51:
When the No.5 is mounted on a Farmall it takes a longer pto shaft. Found this out when I was young. Dad bought a No.5 on an auction. It had been mounted on a JD A. We switched the hitch from the old one we had on to it be the pto shaft would just barely reach. We had to rebuild and swap the pto shaft off the old mower onto it. The Farmall shaft was about 6 inchs longer.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
