Uh, no. Not on the Farmalls. The pulley on the water pump is made in two halves, and the belt is tightened or loosened by moving those 2 halves closer together (tighten) or further apart (loosen).
Likewise the generator pulley is made the same way.
Find the set screw on the pulley. It will probably have a lock nut on it. Loosen the nut, and then back the set screw out. The outer half of that pulley is on threads, just screw the pulley either in, or out, to achieve the proper tension, tighten the set screw, making sure it is IN a groove, tighten down the lock nut and you're good to go.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
