Re: Farmall 100 Fluids
Posted by equeen on September 15, 2012 at 17:17:25 from (209.102.248.236):
In Reply to: Re: Farmall 100 Fluids posted by ken house on September 15, 2012 at 16:40:20:
Thanks Ken and Jan.
Actually, I have a slight problem in checking the fluid level at the fill plug. Also have a problem in filling my left rear final drive oil pan.
The fill/level plugs have been botched-up beyond use. (I'm thinking of taking the tractor to a welder and let him see if he can weld a grade 8 bolt or something in the square holes to allow me to back out and replace the plugs. Other ideas welcomed.)
I flushed the trans and replaced the fluid last year, just needed a final check after finishing work on it. (I simply drained it again, measured the fluid and re-filled at 4.5 qts.)
As to the final drive, I filled the oil pan - oops too full - and re-installed pan with oil. Still, I want to replace the damaged plug so that the next owner will not have this problem.
