Re: Distillate fuel strainer fitting
Posted by gene bender on September 15, 2012 at 19:08:23 from (67.55.227.72):
In Reply to: Distillate fuel strainer fitting posted by Senator on September 15, 2012 at 18:39:32:
That system needsa inlet port from the gas tank and then the outlet to the carb. You will probably need to make a new line from the sediment to the carb. Use steel brake line for that line. The fitting on the brake line will work either for the carb end or the sediment end and you can use a ferulle on the other end.I make lines for the As and Bs.
