Re: M Belly Pumo
Posted by D Slater on September 16, 2012 at 07:43:26 from (184.15.50.155):
In Reply to: M Belly Pumo posted by John M on September 16, 2012 at 05:57:44:
Unless the control arm is not moving the shaft going into the liftall housing its going to have to come out. Once the back plate is removed from the reservoir its pretty simple to see and figure out how the linkage works. For some reason the check ball is not being pushed off the seat to let the fluid back, unless the plunger that moves to pump or bypass is staying in the pump position. If its just a problem with the one ball check he may get lucky and move the line and operate it. If pressure line is connected to the right side opening, move it to the left rear or vice versa. Those openings use a different check ball to let the pressure back.
If the internal linkage is apart or broke that works them it won't work though.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
