Re: properly time h with distributer
Posted by D Slater on September 16, 2012 at 08:01:43 from (184.15.50.155):
In Reply to: properly time h with distributer posted by crl800 on September 16, 2012 at 07:25:19:
Unless you have a timing light that can be adjusted or a front pulley marked for maximum advance set timming with the engine not running. Jim N. give instructions on one way to do it in a recent post on timming a M tractor. Should find it in a post just a page or two back. After setting the initial timming unless you know what the distributor advance is or if its in good shape timming may not be as recomended at all RPM ranges after that though. To check on a tractor the pulley needs to be marked in the correct places or the adjustable timming light used.
