Re: Damaged fill/level/drain plugs
Posted by Red Mercury on September 16, 2012 at 09:28:16 from (204.112.24.251):
In Reply to: Damaged fill/level/drain plugs posted by equeen on September 15, 2012 at 18:43:56:
Easy-outs make an excellent Christmas gift for someone you don't like. Rarely do they work if the broken bolt or plug is at all seized in the threads. Often with bolts they will make the problem worse by expanding the bolt in the threaded hole. Or the easy-out will break off in the hole...then what?
The other ideas are worth a try and have been successful. Since it is a fill/level plug it likely is not rusted because it would have oil on the other side. Depending how bad the dammage to the plug is I have been able to put the end of a wrecking bar (claw bar) cross ways in the square of the plug and turn it with a big crescent wrench. Heating the casting around the plug at the same time with an oxy-acetylene torch would help as well but will mess up the nice paint job. I only heat something like that as a last resort because of the risk of damaging something else with the heat.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
