IH 544 Hydro
Posted by Phil Tibbetts on September 16, 2012 at 11:25:25 from (208.93.14.38):
Well I got the brake freed up and had it running but it sounds like tin rattling inside the bell housing area. I am thinking maybe a torque plate failure? When I first started it the 3PH raised slowly but after I let it down it would not lift again. When I split it can the break be made without removing the side frames? I am hoping I can remove the bolts into the motor and just roll it apart. Maybe just loosen the others. Is that possible or am I hoping for too much?
