Re: Damaged fill/level/drain plugs
Posted by Mark Peters on September 16, 2012 at 12:03:41 from (66.222.7.148):
In Reply to: Damaged fill/level/drain plugs posted by equeen on September 15, 2012 at 18:43:56:
I vote for welding a nut on the plug , or if you have access to square steel stock of whatever size that the plug takes (1/2" ?),stick a couple inch long piece in there and weld that in. That being said, if you want to try the easy out method, if you have left hand drill bits, use them and sometimes you get lucky and they`ll catch and back the screw or plug out so you don`t even need to use a easy out.
