Re: H-4 Magnetp
Posted by pete 23 on September 16, 2012 at 18:12:43 from (74.32.238.2):
In Reply to: H-4 Magnetp posted by A.Lambert on September 16, 2012 at 17:09:28:
Turn magneto backwards to nearly line up number one. If you go a little too far you will get on windup side of impulse so just turn it around again to (close to number one). If it is timed correctly internally it will go right on then do you fine timing so it trips just slightly after tdc. Not before.
