Re: Farmall 460, no oil pressure?
Posted by pete 23 on September 16, 2012 at 18:17:22 from (74.32.238.2):
In Reply to: Farmall 460, no oil pressure? posted by CJ Johnson on September 16, 2012 at 16:27:20:
Remember also, that is a full flow oil filter so it has to fill before gauge will read pressure. I like to just leave the gauge hole open, no spark plugs, ground or unhook coil so no spark from by pass circuit, and crank until oil comes out. You will not hurt an engine with starter cranking even with no oil pressure as you have no heat or pressure build up.
