Hmm, so they are only good for 798 lbs each bolt? That would make the load for the tie down 1596 lbs? Is the saftey factor a mandatory thing or just extra cautious?
Nobody said you had to use the bolts they were designed for. Hex bolts will work just fine in them. They just don't fit nice and flush. I really don't think the bolts will be your problem. I would guess the wood will crack or the bolts will pull through where the wood is fastened to the metal. I would really like the see the tie downs through bolted through the metal.
Tom you and I usually agree, but I don't think a low top speed and local hauls only equals a safe situation in this case. It isn't you that you need to worry about...
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
