Re: H-4 Magnetp
Posted by gene bender on September 16, 2012 at 18:31:25 from (67.55.226.233):
In Reply to: H-4 Magnetp posted by A.Lambert on September 16, 2012 at 17:09:28:
You probably got the rotor out of time with the tower. It needs to be lined up with the tower when it impulses. you can move the gears to get the rotor so it lines up on the tower when it impulses. You also need to make sure both valves are closed on #1 to make sure you are on TDC.
